DAVE™ Forum Discussions
Is there a way to change Derivate/Package in an existing DAVE4 Project?
(I can only find a selection, if I create a new project with Project Wizzard.)
Can I do same in existing project?
Thanks for help.
HI,
It is possible to do a device migration in DAVE. However, this currently only supports devices in the same series.
In the "C/C++ Projects" Tab, select your active project.
- Right click to select "DAVE Project Upgrade".
- Select "Device Migration".
- In the open dialog "Device Migration", you can select the device variant to migrate your project to.
Daryl
OK, Nice...
Thanks for help!
