I want to add the eclipse marketplace but I cannot connect to http://download.eclipse.org/releases/neon/
I get the following error with http:
HTTP Server Unknown HTTP Response Code (301):http://download.eclipse.org/releases/neon/content.xml
General connection error with response code=301
and with https:
Unable to read repository at https://download.eclipse.org/releases/neon.
HTTP Server Unknown HTTP Response Code (301):http://download.eclipse.org/technology/epp/packages/neon/content.xml
I tried it with DAVE 4.4.2 and a fresh install of DAVE 4.5.
With DAVE 4.4.2 I already did connect successfully to said server some time ago, but now it is not working anymore.
The server itself is working (e.g. STM32CubeIDE can access it over http and https).
DAVE has internet access, e.g. https://download.eclipse.org/eclipse/updates/4.6/ is working - interestingly http is not:
HTTP Server Unknown HTTP Response Code (301):http://download.eclipse.org/eclipse/updates/4.6/content.xml
Any ideas?
DAVE™
Hi ,
The latest plugins are available on "Eclipse Project Updates" and not on the neon. Go to help -> Install new software. Inside the new tab open "Available Software Sites" option. Inside that select Eclipse Project Updates and not neon. After that select the same in Work with field and select the resource you need.
If you are working within your organization make sure that you don't have a firewall preventing you from connect. You can manually set up the settings in Window -> Preferences -> General -> Network connection and provide manual settings.
Vasanth
But the marketplace is not available there. In need the Neon site.
Hi Fraenky,
Thanks for sharing the solution with the community 😀
Vasanth
