Mar 31, 2016
07:18 AM
Mar 31, 2016
07:18 AM
I am new to DAVE. I have just installed DAVE version 4.2.4. I have installed all the APPs and Library Manager from Help/Library Manager Wizard.
I have created a new Dave CE project and selected my microcontroller (XMC4500-E144x1024). When I try to add an APP I get the following message:
What am I doing wrong?
I have also tried to import an example project, but I cannot see any APPs. I have no idea how to use the examples.
The first steps with DAVE seem to be VERY difficult and not for beginners.
07:31 PM
Mar 31, 2016
07:31 PM
HI,
It seems that the device description for XMC4500 series on your system needs an update.
If you have not updated, you can update your system using the following steps:
- Goto "Help-> Check for Updates" : This will list the APPs and Device Description on your system that need an update.
Can you try this step and let me know if it is working on your system. 🙂
Daryl
Daryl
Mar 31, 2016
11:09 PM
Mar 31, 2016
11:09 PM
This does not seem to be the problem. I have updated everything. If I go to "Help->Check for Updates" I get this message:
So I assume everything is upto date.
11:40 PM
Mar 31, 2016
11:40 PM
HI,
In this case, can you try to reinstall the device description on your system.
- Goto "Help-> Install DAVE APP/Example/Device Library..."
- Select "DAVE APPs Library Manager"
- Uncheck the filter "Hide items that are already updated"
- For the libraries, select Device Pack and Library DAVE Description, then Select Next to update the installation again.
Daryl
Daryl
Apr 01, 2016
01:32 AM
Apr 01, 2016
01:32 AM
No, this did not help!
I download and installed the Device Pack and Libraries and then restarted DAVE, but nothing has changed. I still get the same error message when I try to add an APP.
01:42 AM
Apr 01, 2016
01:42 AM
HI,
Can you send you .log file from your system to help you analysis your project issue. You can follow the steps in this link to extract the log file.
https://www.infineonforums.com/threads/3400-DAVE-TIP-of-the-day-Extracting-the-DAVE4-logfile-(.log)-...
Also, please provide your system information, DAVE version, Windows OS version for us to help diagnose this.
Daryl
Daryl
02:33 AM
Apr 01, 2016
02:33 AM
From the .logfile that you have provided, it seems that the DAVE library store was not installed properly or has been corrupted during the installation.
That seems to be the cause of your problem.
Therefore, I would recommend you to delete your DAVE librarystore and reinstall your library store again.
- Close DAVE IDE.
- Delete the DAVE library store folder manually.
- Re-launch DAVE
- Select "DAVE APPs Library Manager" to install the DAVE libraries again.
To know where your library store is installed, in DAVE4, you can goto: "Windows->Preference->DAVE->Library Manager"
From the logfile you provided, it is from this location: C:/Users/amanning/Infineon/D_LibraryStore_4.1
Could you try this please.
Daryl
- Close DAVE IDE.
- Re-launch DAVE
Daryl
Apr 01, 2016
02:55 AM
Apr 01, 2016
02:55 AM
I will try this next week. Thanks for the help so far.
Apr 04, 2016
12:01 AM
Apr 04, 2016
12:01 AM
OK, that seems to have solved the problem. I can now add APPs to a new project and edit APPs in the examples projects.
There muss be a bug in the installation routine somewhere.
Is there a DAVE 4 example or APPs for the USIC in I2S mode available?
03:08 AM
Apr 20, 2016
03:08 AM
HI,
I2S is supported on XMCLib. At the moment, I do not have any example in DAVE4 on this. 😞
Daryl
Daryl
Apr 20, 2016
05:35 AM
Apr 20, 2016
05:35 AM
I have solved the I2S problems but I cannot get the DMA to work correctly, see my post "DMA Problems".
