05:45 PM
Nov 18, 2015
05:45 PM
I have installed Dave 4.1.4 and did all updates.
But i cannot select new Apps in a project. For example in a XMC1300 project I want to use the BUCK_VOLT_CTRL App. But under Power Conversion
I only can select between Comp_Ref, PWM_CCU4 and PWM_CCU8.
Where can I find the other Power Conversion Apps or Power Conversion Libs?
The APPs themself are installed in the folder: Infineon/D_LibraryStore_4.1/resources/....
There are no more updates available.
kind regards MPK
kind regards MPK
03:38 AM
Nov 27, 2015
03:38 AM
The APP you are looking for is released as Beta version. In the Add APP selection view there is a check box “Hide beta version” . The box is checked by default, If you un-check it you should be able to add the BUCK APP.
