User15614
I cannot create a new project after i import some of my project, maybe i somehow changed my Dave Settings, but i don't know how to get it back to normal.
AS YOU CAN SEE in thepicture, i just can't go to the next step (click not response). I encounter this problem recently in Dave 4.4.2 and Dave4.3.2 , any kind suggestions?
jferreira
5 sign-ins First like received 750 replies posted
Most probably is an issue with missing device descriptions in your Library Store.
Please check that in Help>Preferences, DAVE>Library Manager, the Library Store path is correct. The folder pointed by the path should contains the folders DeviceFeatures and resources.
Additionally you can create a new workspace, bear in mind that old workspaces created with DAVE4.3.2 are not compatible with DAVE4.4.2
Once you have a new workspace open, check that in Help>Preferences, DAVE>Library Manager>Library Update Sites, you have listed http://dave.infineon.com/Libraries/DAVE_Libs/XMC_IFX/v4.4/daveSite.xml which points to the latest version of APPs, device pack and device descriptions.
Now try Help>Check for DAVE APPs Update.
User17893
I had the same problem after renaming my DAVE installation folder. After renaming it back to its old name, everything was fine again.
User17916
Thanks, jferreira, for the solution to my problem.
I recently installed DAVE on a new laptop and copied the Workspace folder from the old one, and I could no longer create new projects.
The path to the Library Store needed correcting since it was different from before.
