09:00 PM
Aug 20, 2013
09:00 PM
Hi all,
I 'm using XMC4500 step AB to do my project. When I select XMC4500 F144x1024 Stepping Code AB as MCU, then the CAN001 APP[1.0.6] can not work. But when I create another project with XMC4500 F144x1024 Stepping Code AA, it can successfully sent out the CAN message. All the setting are the same. So I am confused where's the difference. Attached file please find the project of Stepping Code AB for analyze. Thanks.
BR,
Morris
BR,
Morris
02:54 AM
Sep 03, 2013
02:54 AM
Hi morris,
There is a know issue in CAN001[1.0.6] which will be fixed soon. So the project built with CAN001[1.0.6] should not work on AA-step device as well. I was wondering that your working project on AA was using older version app?
Sophia
Sophia
06:57 PM
Sep 03, 2013
06:57 PM
Hi Sofia,
After checking the project, I indeed use CAN001[1.0.0] rather than CAN001[1.0.6] in my project with AA-step device. The CAN001[1.0.6] does not work on AA step device as well as you say. So when the issue will be fixed. Is there any schedule?
Morris
Morris
11:59 PM
Sep 03, 2013
11:59 PM
Hi Morris,
The official release should be around one week time.
Sophia
Sophia
03:01 AM
Sep 11, 2013
03:01 AM
Hi all,
using CAN001 1.0.6 and relax kit. Although defined, no pin configuration in CAN001_Init(). It is the same problem as mentioned above (after several days of investigation). I removed 1.0.6 from my project in added 1.0.0 and it configures Rx and Tx...
Detlef
Detlef
02:11 AM
Sep 12, 2013
02:11 AM
06:45 AM
Sep 30, 2013
06:45 AM
Hi Sophia,
since I think I am struggeling with a similar Problem:
Could you please provide the patched functions...
As I could see from the eTicket, there seams to be something missing in the code. From the eTicket
this should be in the function CAN001_Init(). Sine there is no var CAN_NodexRegs I think it is probably missing
in CAN001_lNodeInit(). Could you please Point me to the right place.
Volker
Volker
12:59 AM
Oct 01, 2013
12:59 AM
Hi Volker,
Did you update to the latest DAVE 3.1.8? This has been fixed in CAN001 [1.0.8]. Will update the eTicket soon.
Sophia
Sophia
01:35 AM
Oct 02, 2013
01:35 AM
Hi Sophia,
thanks. It works with Dave 3.1.8.
..but I really hate These updates. If you are using Eclipse you always have plugins installed. There should be
a way to Import all plugins from the old Dave Version. It takes hours to get Dave back to the state you had before...
02:55 AM
Oct 02, 2013
02:55 AM
Hi Volker,
Thank you very much for the feedback. I will forward this to the responsible person.
Sophia
Sophia
