06:10 AM
Jun 27, 2013
06:10 AM
I imported the DAVE App "ADC001_Example2" but was unable to run it in the debugger due to a "Debug UI" error. I may have accidently made changes to the project.
So I right clicked on the "ADC001_Example2" project in my workspace using DAVE and selected X Delete. This removed the "ADC001_Example2" App from my workspace.
However, if I try and import the "ADC001_Example2" App again using File->Import->Dave Project, the "ADC001_Example2" App is greyed out on the list of available Apps so I cannot import it. I have tried closing and re-opeing DAVE but this has no effect.
Does anyone have a workaround for the problem ?
Thanks very much
Aaron
Thanks very much
Aaron
06:18 AM
Jun 27, 2013
06:18 AM
OK, I found a workaround. Even though DAVE removed the project name "ADC001_Example2" from the project list, the folder "ADC001_Example2" was still present under my workspace folder when I looked with Windows Explorer.
So I manually delated the "ADC001_Example2" folder and I now get the option to import the project again.
Jun 28, 2013
09:47 AM
Jun 28, 2013
09:47 AM
You could have avoided manual deletion if you check to option “ Delete project contents on disk (cannot be undone)” in the control to delete a project.
It is certainly debatable why this is not checked per default, but we kept it as it comes with CDT.
12:07 AM
Jul 01, 2013
12:07 AM
Thank you Georg, my mistake. I found the “ Delete project contents on disk (cannot be undone)” option. I have attached a picture of the dialog.
Aaron
Aaron
