I am looking for a mechanism for my end users to flash the xmc4500 over USB and would appreciate any help or examples for the following...
  • xmc4500 bootloader code
  • PC user interface, ideally a batch file or similar that the end user simply runs without having to select the type of chip, download file name etc.
Thank you in advance
Aaron
Hi Aaron,
You may try to write your own code by using USBVC001 & FLASH002 Apps. USBVC001 App provides VCOM port interface whereas FLASH002 App provides flash erase and program interfaces. Good luck...
Zain
Hi Zain,
Thanks for the advice. My project already uses USBVC001 (though it is not problem free) so I'll look into FLASH002.
Aaron
