As part of the automatic build pipeline, I would like to regenerate code (so the folder DAVE\Generated) of the current model I'm using.
Is there a way to do it by command line instead of opening DAVE CE (currently using V4.5.0) and clicking on DAVE\Generate code ?
Thanks in advance for your help and answers.
Cyril
Hi Cyril,
Unfortunately the code generation and UI automation from CLI is not supported in Dave as of now. This could be possible once we move into ModusToolBox as the primary tool for XMC too.
Vasanth
Hi Cyril,
Vasanth
