Hi all,
i am using Dave4. Is there any example available that shows how to use the touch buttons on the Hexagon HMI board.
I am also interesting in using the voice input/output on the board. Is an example available for that?
Thomas
JungThom wrote:
Hi all,
Thomas
Hi Thomas,
Are you referring to IIS? You may refer to DAVE v3 I2S002 App.
BR,
Zain
Hi Zain,
i will check the IIS from Dave3.
Do you have an example that uses the touch buttons on the hexagon board?
This would be very helpfull.
Thomas
Hi Zain,
did you have a chance to check if there is an example for Dave 4, that uses the push buttons on the Hexagon board?
Thanks for Help
Thomas
Hi Thomas,
I thought you have already got the example from "HMI with Dave4"?
BR,
Zain
Hi Zain,
no i didn´t get anything 😞
Thomas
