Dec 13, 2014
09:50 AM
Dec 13, 2014
09:50 AM
Two similar questions:
1. I have non Dave project. Is it possible to convert it to Dave and start adding applications? (of course without having to re-create the Dave project from scratch)
2. I have deleted Dave folder from Dave project. Adding apps still works, and Dave folder is re-created. However, it is missing content of DAVESupport folder. How can I get it back?
Rum
Rum
10:00 AM
Dec 13, 2014
10:00 AM
I have disocvered that after insisting several times "Generate Code" also DaveSupport folder is re-created but with files containing some wrong information, probably some content of apps in cache. There is certainly a bug.
01:01 AM
Dec 15, 2014
01:01 AM
Hi Rum,
1) It is not possible to convert a non DAVE CE project to DAVE CE project;
2) Did you use "Generate Code" to re-create the Dave folder? The Dave folder contains lots of important files eg. templates which are unable to be re-generated by simply click "Generate Code". This is an illegal operation.
Sophia
Sophia
