01:14 AM
Apr 17, 2013
01:14 AM
Hallo,
i have an RUNNING projekt where i use the USBVC001, GUISL001 and PWMSP001 apps allready.
When ever i try to add the ADC001 i cant rebuild the projekt anymore.
There are no problems with the "solver" or " generate code" but rebuilding
ends up with: make: *** Error 1
Any ideas?
Any ideas?
07:55 PM
Apr 18, 2013
07:55 PM
Could you pls provide your project configuration details eg. signal connection and pin assignments etc.? If possible, send us the .log file which can be found in workspace folder\.metadata\
(ex: C:\Temp\DAVE_CE_WS_v316\.metadata)
Sophia
Sophia
12:37 AM
Apr 19, 2013
12:37 AM
First of all: Thank you Sophia!
I am trying to get this running for 5 Days now and sill cant make it work.
I even started from scratch a few times, nothing! When ever i add the ADC001
i cant rebuild.
I put all the info you asked for in the attachments.
Thank you again in advance.
Gunter
i cant rebuild.
Gunter
02:28 AM
Apr 19, 2013
02:28 AM
I just found out that if i empty my main.c it rebuilds.
Could it be that there is a conflict there?
03:00 AM
Apr 19, 2013
03:00 AM
I've built a project using XMC4500-F144x1024 according your configurations. It can be compiled without error. Of course, the main.c is empty. But I am unable to confirm whether this is the cause? Let's check the Apps version/connectivity 1st. The App Connectivity in my project is a slightly different to yours (highlighted an example). Attached is the Apps version I used (the latest release DAVEAppsLibrary001 v 1.0.38). Could you pls check yours?
Sophia
Sophia
03:42 AM
Apr 19, 2013
03:42 AM
Thanks for the fast reply.
I am also using the XMC4500-F144x1024, so it cnt be that.
I checked the report and found that i have a MOTORLIBS/0 in it but the rest seems to be the same.
Just for your ensurance i attatched the screenshot. As far as the connectivity goes its the same.
I reasambled mine to look like yours, as can be seen in the attatchment as well. I also added my main.c
with the working code (as long there is no adc in my projekt).
Gunter
Gunter
01:28 AM
Apr 22, 2013
01:28 AM
Hallo again,
I finnaly figured out what was wrong:
the makefile called the libraries in the wrong order, it called:
"-lm -lguisl001_WithoutMouse"
instead of
" -lguisl001_WithoutMouse -lm".
Normally it shouldnt make a difference but somehow it did.
Thanks to all who tryed to help.
Gunter
instead of
Gunter
01:34 AM
Apr 22, 2013
01:34 AM
Hi Gunter,
I just found the issue. The SEGGER GUI library has to be listed above the math library (m) in project settings. Press >Project >Active Project Properties >C/C++ Build >Settings >ARM-GCC Linker >Libraries move "guisl001_WithoutMouse" above "m" The details is documented in Apps help file: Go to > Help > Help Contents > DAVE Apps>GUISL001[1.0.14] GUI_SeggerLib_GUISL001 App > App Configuration Documentation
Sophia
Sophia
