Jun 09, 2016
12:38 AM
Jun 09, 2016
12:38 AM
I am trying to evaluate the ADCs on an XMC4400 mcu. I use the XMC4400 CPU-44A-V2-003 Hexagon eval board
I use Dave 4.2.8 with latest APPs, Libs, and examples
Following the instructions given in the Readme_ADC_MEASUREMENT_ADV_EXAMPLE_XMC45.pdf
document, simply does not work
Here is the components / signals view :
And source code :
I was able to add code to generate Request events Interrupts. But no way to get a Result interrupt.
What do I miss ?
I am not sure of what is wrong, starting to wonder if the APPs approach is the right one...
Thanks for any welcome input
Jorge
And source code :
What do I miss ?
Jorge
01:01 AM
Jun 09, 2016
01:01 AM
Found it !
There was a missing setting on the ADV_MEASUREMENT_APP
(Not explicit in the example manual)
01:22 AM
Jun 29, 2016
01:22 AM
HI Jorge66.
Glad that you managed to get your example working.
In case, there is a section in the APP Help documentation, "Usage", that gives a simple use case on how to configure the APP. Hopefully, that will help you save some time in future when working with the APPs! 🙂
Daryl
Daryl
