The sensitivity settings and full-scale output voltage range define the maximum difference in magnetic flux we can measure between the two hall elements. What is not clear from the datasheet, is the maximum magnetic flux each hall element can experience without saturation or signal deterioration. Do you have this information available?
Hii Shaun,
Thank you for reaching out to us.
Looking into your question, " maximum flux each hall element can experience without saturation or signal deterioration", Infineon monolithic Hall technology enables accurate and highly linear measurements of the magnetic field caused by the currents. With a full scale of +/- 31 mT, TLE4972 current sensor is capable of measuring upto 2000A.
Hope this is helpful.
Thanks and Regards,
Adithya
