is the S2Go Platform capable of programming the TLI4971?
As the information about the S2GO is not mentioning the Voltage of ~20.5V, which is referenced for programming in the TLI4971 DS/AN, I fear that the S2GO is only capable of writing settings in a volatile way to the TLI4971.
Please let me know if I missed a way to program the TLI4971 via S2GO.
Veit
Hi @Starostve ,
By S2Go Platform you mean the Current 2Go GUI, right?
If that's the case, your assumption is correct. It provides a Volatile Settings feature, where you can create new configuration as needed. These configurations are stored in RAM of the device. For further details you could go through the following Current sensor TLI4971 MS2Go and S2Go User Manual Section 3.2.1.
Yashraj
Hi @Starostve ,
Yashraj
