Thank you for posting on Infineon Community.
The NC pads of the package are not connected to the die inside the package.
You can refer to chapter 1.5 of the following app note:
https://www.infineon.com/dgdl/Infineon-Board_Assembly_Recommendations-Gullwing-Package-v05_00-EN.pdf...
Example:
Therefore, the drain pads can be connected to the NC pads.
Source pads however, should not be connected to the NC pads, as this creates creepage issues.
Pablo
Example:
Pablo
