CoolGaN™
User19220
First reply posted First question asked
Is it ok to connect NC pads to either of Drain, Source terminals? In the layout, due to the NC pins being adjacent to the Drain pins, the drain copper pour is shaped weirdly and this limits the number of vias I can place on it.
Connecting NC pads with Drain would give me a nice rectangular pour which will make routing easier and more vias can be added for higher current capability.
Also, will connecting NC pads with Drain/Source cause emissions? Or affect the package working internally?
Pablo_EG
Moderator 250 sign-ins 250 replies posted 25 likes received
The NC pads of the package are not connected to the die inside the package.
You can refer to chapter 1.5 of the following app note:
https://www.infineon.com/dgdl/Infineon-Board_Assembly_Recommendations-Gullwing-Package-v05_00-EN.pdf...
Example:
Therefore, the drain pads can be connected to the NC pads.
Source pads however, should not be connected to the NC pads, as this creates creepage issues.
Pablo
User13282
First solution authored
The NC pads are not bonded internally to the die. You may connect the NC pins to the drain pins.
User19220
It'll be extremely helpful and useful of you guys if you give a timely reply. Replying after 2 months doesn't even make sense and I don't think you really have to be in your office to reply
Pablo_EG
Example:
Pablo
