Community Translations Forum Discussions
SaAo
Dear Supporter I want to translate the following KBA. Please confirm to my work.Modifying the DFU basic code example to run the bootloader application... Show More
NXTY_hayashi
Hi, I want to translate the following article. Please confirm to my work.KBA "Is the UART driver available in SDK?"URL: https://community.infineon.com/t5/Knowledge-Base-Articles/Is-the-UART-driver-available-in-SDK/ta-p/721022... Show More
NXTY_hayashi
Hi, I want to translate the following article. Please confirm to my work.KBA "Does I²C driver support both slave and master mode?"URL: https://community.infineon.com/t5/Knowledge-Base-Articles/Does-I-C-driver-support-both-slave-and-master-mode/ta-p/721025... Show More
NXTY_hayashi
Hi, I want to translate the following article. Please confirm to my work.KBA "How does SPI transfer of NAC1080 work?"URL: https://community.infineon.com/t5/Knowledge-Base-Articles/How-does-SPI-transfer-of-NAC1080-work/ta-p/721018... Show More
NXTY_hayashi
Hi, I want to translate the following article. Please confirm to my work.KBA "How to check the communication of the UART using a hyperterminal?"URL: https://community.infineon.com/t5/Knowledge-Base-Articles/How-to-check-the-communication-of-the-UART-using-a-hyperterminal/ta-p/721016... Show More
NXTY_hayashi
Hi, I want to translate the following article. Please confirm to my work.KBA "How to implement a timer with 1 millisecond (ms) count?"URL: https://community.infineon.com/t5/Knowledge-Base-Articles/How-to-implement-a-timer-with-1-millisecond-ms-count/ta-p/721046... Show More
NXTY_hayashi
Hi, I want to translate the following article. Please confirm to my work.KBA "ap_max_inactivity timer in AIROC™ Wi-Fi combo devices in SoftAP mode"URL... Show More
NXTY_Nishinaga
Hi ,I want to translate the following KBA239534 into Japanese, please confirm to my work. https://community.infineon.com/t5/Knowledge-Base-Articles/EZ-PD-PMG1-How-to-modify-USB-PD-DRP-firmware-to-support-a-different-PD-buck/ta-p/704503... Show More
NXTY_hayashi
Hi, I want to translate the following article. Please confirm to my work.KBA "How do you choose KFQ coefficient, and is there any dependencies?"URL: https://community.infineon.com/t5/Knowledge-Base-Articles/How-do-you-choose-KFQ-coefficient-and-is-there-any-dependencies/ta-p/721062... Show More
NXTY_hayashi
Hi, I want to translate the following article. Please confirm to my work.KBA "Is rad hard P-channel MOSFET JANSR2N7660U3CE a replacement for JANSR2N75... Show More
