Hello
I would like to translate below application note into Japanese.
"Magnetic speed sensor - How to protect TLE4921-5U in harsh EMC environment"
Home > Products > Sensor > Magnetic sensors > Application Notes
https://www.infineon.com/dgdl/Infineon-TLE4921-AppNoteHowToProtectTLE4921InHarshEnvironment-Applicat...
Please confirm to my work.
Thank you & Regards,
Masaya
Hi, Masaya-san
I'm trying to connect this page, but it seems not working. (Searched Google also,)
Maybe it will be a temporary issue.
Meanwhile, have you download this file as a pdf?
If so, please let me share with me, then I can check up more fast with team.
Hi, Masaya-san
Initial translation version is ready and attached.
Would you review the attached one - compare to Original English version?
If you think translation is not correct, or unnatural, You can freely update the content based on your review.
When your review is done, would you attach file again to this page?
Also, if you have any question, please let me know.
Masaya-san
Thank you for providing the pdf.
I will pass this into internal review.
