Community Translations - Choosing the right pressure sensor
MaKi_350451
Level 5
Level 5
100 sign-ins 5 solutions authored 50 sign-ins
Hello
I would like to translate below application note into Japanese.
- Choosing the right pressure sensor (AN_201610_PL38_01)
https://www.infineon.com/dgdl/Infineon-AN%20Choosing%20the%20right%20pressure%20sensor-AN-v01_00-EN....
You can find this document under below path on your site.
Home >Products >Sensor >Pressure sensors >Barometric (BAP) & Manifold (MAP) sensors >Applocations
Please confirm to my work.
Thank you & Regards,
Masaya
MaKi_350451
Level 5
Level 5
Hello Wayne-san,
Thank you for your confirmation.
I translated this application note ( AN_201610_PL38_01) into Jananese as attached file.
Please check it.
Masaya
MaKi_350451
Level 5
Level 5
How about this Translation?
Masaya
WayneT
Community Manager
Community Manager
Community Manager
Hi Masaya-san,
Thank you for your participation request.
I will get back to you with the initial machine-translated draft which you can then work and update on.
Wayne
MaKi_350451
Level 5
Level 5
Hello Wayne-san
Thank you for your support.
How about this translation?
Masaya
WayneT
Community Manager
Community Manager
Community Manager
Hi Masaya-san,
Apologies for the long delay.
Please find the the initial translated file attached.
Do let me know if there is any issue with the document.
Wayne
MaKi_350451
Level 5
Level 5
Hello Wayne-san,
Please check it.
Masaya
WayneT
Community Manager
Community Manager
Community Manager
Hi Masaya-san,
Thank you for the revised translation draft. I have forwarded it to our internal team for review.
Will get back to you once it is finalized.
Thank you for the support.
Wayne
WayneT
Community Manager
Community Manager
Community Manager
Hi Masaya-san,
Thanks for your work on the translated AN.
Please find the complete reviewed version attached.
It is also published on Infineon's website at the following URL:
https://www.infineon.com/cms/jp/product/sensor/pressure-sensors/pressure-sensors-for-iot/#!?fileId=8...
Thanks for the great work as always and we look forward to continuing working with you on Community.
Wayne
