Community Translations
NaTa_2243041
Valued Contributor
I tried to translate following KBA229274 into Japanese.
S6BT112A CXPI Transceiver: CBUS Range – KBA229274
Community Translated by
https://community.cypress.com/people/NaTa_2243041
Version **
タイトル:S6BT112A CXPIトランシーバ:CBUSの容量レンジ – KBA229274
質問:
次の図(S6BT112A データシートに記載されている CXPI BUS負荷接続)のCBUSの容量レンジを教えてください。
回答:
CBUS(システム容量)、CMASTER(マスターノード容量)、CSLAVE(スレーブノード容量)のレンジを表1に示します。
詳細については、JASO D 015-3 を参照してください。
T.Naoki
JennaJo
Hello, Naoki-san
We receive your translation, it will be published to KBA to Community.
It will be reviewed internally.
After upload, You will receive the points as the word of KBA.
Due to the current volume of works (waiting review, etc.), Please bear with me for the delayed the response.
It could be delayed, but it will be processed soon.
Thanks for your contribution to CDC!
Will keep you update the status.
Jenna Jo
Jenna Jo
Top labels
