Community Translation - S6BP401A Power Requirement - KBA229653
YoOb_1790021
First solution authored 10 likes received 10 likes given
I tried to translate this KBA229653 into Japanese.
https://community.cypress.com/docs/DOC-19432
タイトル:S6BP401A 電源要求
質問:
もし、PVCC 電圧が保たれた状態で、VCC電圧が低下した場合、問題が起こりますか?
回答:
はい。VCC電圧がPVCC電圧を下回ると、デバイスが誤動作する可能性があります。データシートで推奨されているように、PVCC は PCB上で VCCに接続する必要があります。
参照:
S6BP401A Datasheet
obana
JennaJo
Hello, Obana-san
We receive your translation, it will be published to KBA to Community.
It will be reviewed internally.
After upload, You will receive the points as the word of KBA.
Due to the current volume of works (waiting review, etc.), Please bear with me for the delayed the response.
It could be delayed, but it will be processed soon.
Thanks for your contribution to CDC!
Will keep you update the status.
Jenna Jo
Jenna Jo
