Community Translation - Knowledge Base Article #10
Praveen
25 solutions authored 10 likes given 5 likes given
Community Translation program details here.
KBA # 10 - Rise and Fall time specifications for SCL and SDA lines of I2C
Translation from English to Japanese - Open
Translation from English to Chinese - Open
Please acknowledge in this thread as a response if you want to translate this Knowledge Base Article for the community
Download the attached KBA document,
Append with your translation in the document,
Submit the translated KBA document back as a response in this thread for review.
Cheers
Praveen
Cheers
Praveen
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Dear Praveen-san,
I'd like to translate this KBA.
9-Aug-2019
Motoo Tanaka
Praveen
Moto san,
Thanks for your continued contributions for the community.
Translated KBA is now live in CDC.
Hope to see many more translations from the community.
I2C の SCL と SDA 信号の立ち上り(Rise)時間と立ち下り(Fall)時間の仕様 - Community Translated (JA)
Cheers
Praveen
Cheers
Praveen
kama_1693131
50 sign-ins 25 sign-ins 10 likes received
Hi
I tried to translate this KBA#10 into Chinese.
Community Translated by https://community.cypress.com/people/kama_1693131
Version **
标题:I2C的SCL和SDA线的上升和下降时间规范 - KBA#10
PSoC器件中I2C通信的SCLSDA线的上升和下降时间规范是什么?
回答:
PSoC完全符合飞利浦I2C总线标准,该标准可从以下链接下载。
http://www.nxp.com/acrobat_download/literature/9398/39340011.pdf
下表显示了全速和标准运行速度下SCL和SDA线的上升和下降时间规格。
参数
    标准模式(100KHz)
    快速模式(400KHz)
单元
最小
最大
最小
最大
上升时间
(对于SCL和SDA)
    _
1000
20+0.1Cb*
300
ns
下降时间
(对于SCL和SDA)
    _
300
20+0.1Cb*
300
ns
*Cb -> 总线总容量,以pF为单位
JennaJo
We receive your translation, it will be published to KBA to Community.
After upload, You will receive the points as the word of KBA.
Please bear with me for the delayed the response,
Thanks for your contribution to CDC!
Will keep you update the status.
Jenna Jo
Jenna Jo
JennaJo
Your translation has been released, sorry for the delayed process.
I2C的SCL和SDA线的上升和下降时间规范 - Community Translated (ZH)
Thanks for your contribution to Cypress Developer Community!
As a token of appreciation, you will receive the point.
Thanks for continuous contribution on Community.
Jenna Jo
Jenna Jo
