Community Translation - AN205353 - FM3 MICROCONTROLLER WITH ELECTRICAL BRAKE APPLICATION ON BLDC WASHER
keni_4440091
Level 7
Level 7
500 replies posted 100 solutions authored 50 solutions authored
Hi
I want to translate the following AN, please confirm to my work.
Nino
JennaJo
Hi, Nino-san
Confirm to work this AN.
Attached is translation machine version,
Would you review the translation and update with your input?
It would be good that you can mark your changes as red color or turn on track changes.
Jenna
Jenna Jo
Hi
I have reviewed and updated with RED wording as attached file.
Please confirm and double check.
Nino
JennaJo
Hi, Nino-san
Thanks for your review work.
I will pass this review to internal team and get back to you when review is done.
Jenna
Jenna Jo
JennaJo
Nino-san
Thanks for your work.
Your work is reviwed completed.
Attached is updated version from Techpub.
You will received score based on your work, I will get back to you - after I complete score.
Thanks for your work on Community.
Jenna
Jenna Jo
