Dear Supporter
I like to translate the following AN, please confirm to my work.
AN1909 - Isolated gate driving solutions
Nino
Gate Driver IC
HI, Nino-san
Sorry to say that AN1909 is already taken, but we have a AN201702.
If you have an interest to look into below AN, please let me know.
Otherwise, if you want to look at similar AN type as AN1909, also please let me know, I can hep to get it.
1. IFX AN 201702
power conversion - CoolGAN
This document describes the main features of Infineon’s 600 V CoolGaN™ enhancement-mode (normally off)
gallium nitride (GaN) power transistors.
Jenna
Hi Jenna
Ok, I will try to translate the following AN. Please confirm to my work.
IFX AN 201702
Nino
Dear Jenna
I just started to translate in Japanese for this AN. And I'm referring Revision 1.0 dated 03-05-2018.
Also I'm referring the initial translated version as V1.0 dated 2018-05-03 which I have send to me.
However English contents is little different between the both even if the both version is the same.
Should I refer the one which you have sent ? And should I ignore the one which is defined on IFX web site as Revision 1.0 in English ?
Please confirm and double check the both version. The following URL shows the original English version (maybe).
Nino
Hi, Nino-san
Sorry to provide the wrong English version. the version # is not matched.
The translation file is correct. but link in thread is not correct.
Would you help to refer to file, and below address?
If you have other question, please let me know.
Thanks for pointing out.
Dear Jenna
Thank you for your prompt feedback.
It seems the file you informed at this time is correct English version.
I will re-process the translation with this version.
Nino
Dear Nino-san,
Thank you for starting translation.
I passed your question to internal team, let you know the response when I have it.
Dear Nino-san,
Jenna
