HI, I'd like to translate AN_2205_PL38_2205_092749 into Japanese, please confirm to my work.
h_nakamura
Hi Hiroshi-san,
Thank you for your participation request.
I will get back to you with the initial translation.
Sharit
Hi Sharit,
Is it OK to start to translate this AN into Japanese now?
H.N
Hi Hiroshi-san,
As per the current process, we will first share a machine-translated draft with you, on which you can then work and update. Once this draft is ready from our end, I will share the same here for you to work on.
Sharit
Hi Sharit,
I'd like to confirm, to create a draft of machine translation is my work, right?
Actually, I've already make the machine translation draft to understand this AN for me.
H.N
Hi Sharit,
What happened to this matter?
Is it OK to attach the translation?
N.N
Hello Nakamura-san,
Thanks for the first cut translation.
Deepest apologies for the long delay since the last response.
I will process the internal review for this.
Will get back to you once it is complete.
Thank you.
Wayne
Hi Nakamura-san,
Thanks for your work on the translated AN.
Please find the complete reviewed version attached.
It is also published on Infineon's website at the following URL:
https://www.infineon.com/cms/en/product/sensor/radar-sensors/radar-sensors-for-iot/60ghz-radar/bgt60...
Also, please refer to the feedback file attached.
Thanks for the great work as always and we look forward to continuing working with you on Community.
Wayne
