JoBr_1593366
100 sign-ins 50 questions asked 100 replies posted
I keep posting questions or problems on this forum, they go unsolved, and then the topic is locked, even though it's still an unsolved problem.  Sometimes a "solution" is even chosen for me that doesn't actually solve my problem.  Why? It's frustrating.  If it stayed open, we could continue putting notes and other people with the same problem could also comment, maybe finding a solution.  But instead, everyone needs to create new topics about the same issue, not seeing each other's posts.
https://community.infineon.com/t5/PSoC-5-3-1/We-were-unable-to-find-the-symbol-There-are-several-thi... is still a problem, for instance.
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi @JoBr_1593366 ,
Sorry for the inconvenience caused, we have unblocked the thread and you can continue the discussion there.
We were able to recreate the issue which you were facing in PSOC3 and we have raised an internal ticket so that we can see if this issue can be fixed.
Alakananda
