sakh_4591951
I have correctly followed the steps of installing "cypress-testrail-reporter".
I configured the cypress.json as
"reporter": "cypress-testrail-reporter",
    "reporterOptions": {
          "domain":"testrail server address",
          "username":my username,
          "password":pwd,
          "projectId":1,
          "suiteId":1
In TestRail/Site Settings/API/Enable API is Checked.
I have written the test cases id as it('C123 is the ID', .....
No test run is created and no test case is run. TestRail logs in Administration/System Log do not contain nothing.
Has anybody performed the Cypress - TestRail integration? I do not understand where it's failing.
Thanks in advance for your help.
Sarfraz Khan.
DheerajK_81
You are in the wrong community forum. There's a thin line between Cypress the microcontroller company which provides embedded solutions and the Cypress.io which is a software company which provides testing solutions. The query you have seems directed at Cypress.io and here's the link to their forum: https://www.cypress.io/support
Dheeraj
DheerajK_81
Dheeraj
