TLE5012BD Set ANGLE_BASE causes "Invalid angle value" in STAT field SAFETY WORD
User20856
by configuring the ANGLE_BASE (register MOD3) with the value 0x800, it happens quite randomly that the error "Invalid angle value" bit12 of SAFETY WORD is generated.
This has happened in one unit after about 100 programmed without problems. If I change the ANGLE_BASE value to 0x7FF or 0x801 the issue doesn't happen.
Could it be a problem of this unit only or am I doing something wrong?
Thank you!
Regards.
User21445
Привет MotterliniM! как твои дела? ты решил свой вопрос?
