Vineeth
I would like to know the values of decoupling capacitors which I need to use with CY8C9560A 60 bit IO Expander for developing schematics.
I have referred the datasheet, Infineon Community question-Answers as well as other other websites such as Digikey,Mouser etc but I could not find any information.
It would be very helpful if anyone one could help me in knowing the values of decoupling capacitors to be used with CY8C9560A.
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Hello @Vineeth ,
You can typically use a 100n capacitor for decoupling the VDD of CY8C9560A. This is a guideline, you may change the value if you find it necessary in your application.
Sampath Selvaraj
Hello @Sampath Selvaraj,
Thank You for your response.
Thanks and Regards,
Vineeth Krishna K
