Community Information
User22572
New Contributor
Good morning,
While testing the PASCO2 evaluation kit I have encountered the following error.
5337.attach
This error occurs randomly and stops the datalogging.
This issue seems to be getting worse by the day.
This makes it very difficult to asses the stability of the sensor.
The datalogging is done on a Windows 10 PC, the evaluation kit is connected with the USB cable provided.
It would be helpful if this error could have a timeout, so the software can try to connect automatically.
Kind regards,
Martin
mickmiles
New Contributor
If you have been putting off hiring a software development team, there are some reasons why you should do so instead. A dedicated software team will work on your project from start to finish, allowing you to control the timeline and budget. In addition, you won't have to worry about managing multiple projects, which can be a challenge for a smaller software development team https://mlsdev.com/blog/how-to-make-a-booking-app. A dedicated team is an ideal choice for large-scale projects where the project is more complex.
