Medallion Instrument Systems Marine Power Module 5509-12064-01 Revision A2
Burned out chip that needs replacement :Manufacturer - International Rectifier 6727 E6VX 1724
Please help identifying this chip and suggest replacement.
Thank you
Hello.
I'm not from Infineon or IR. However, a quick Google search reveals the part number is IRF6727M. It's still made by IR so a direct replacement is possible. Can be purchased at Digikey, Newark, Mouser, but all out of stock at the moment.
Looks like the pcb will need some repair as well.
FYI..., E6VX is a batch code, 1724 is year/week of manufacture (late June of 2017).
Any chance the Power Module still has some warrantee remaining?
Hopefully someone from IR will chime in and suggest an alternate replacement that's readily available.
