Community Information
odissey1
Level 9
Level 9
It appears that links to the outside sources are no longer allowed, and posts with such links are permanently deleted. No draft version remains. This is quite sad, as some legitimate links, for example, to the supplementary YouTube demos are quite useful.
Another issue is that such posts are deleted entirely, not even a draft remains, forcing to manually re-type the entire post. Is it possible to keep at least a draft, so it can be edited and corrected if necessary?
vishnu
Community Manager
Community Manager 25 replies posted First comment on blog 10 questions asked
Community Manager
@odissey1 , circling back on this one to see if you still face this issue. From our side we have reviewed & released the discussions that came into our moderation queue.
In case you can still replicate the problem, it would be helpful to get into a short call and review together. Please let us know. 🙂
-Vishnu
Vasanth
Moderator 500 solutions authored First question asked 1000 replies posted
Hi Odissey1,
Apologies for the inconvenience caused to you. We are working with our community team on this. We will update you at the earliest.
Vasanth
vishnu
Community Manager
Community Manager
Hello @odissey1
Thanks for reporting this issue; we are currently investigating this as top priority. We definitely encourage sharing helpful resources, (even external) with the community members.
While we figure out the root cause and fix it, we are also retrieving the lost content you mentioned. Please check if you see some of them published now.
We will update you shortly once we progress with our analysis. Appreciate your patience and support.
Vishnu
vishnu
Community Manager
Community Manager
-Vishnu
odissey1
Level 9
Level 9
It seems to work now
test link:
https://youtu.be/kw4q21A3omA
