IFX91041EJ V50 VS Pin Connectivity
User12951
I'm using IFX91041EJ V50 to generate +5VDC in my project.
On Page No.13 in section 8.4 IFX91041EJV50, IFX91041EJV33 with fixed Output Voltage :
Is their a reason other than reverse battery protection that Vbat is connected to VS Pin via a diode, Capacitor, Inductor, Capacitor Tank circuit.
I'm using +12VDC (generated using LM2576HV-12) supply to generate +5VDC.
Will using just 100uF capacitors to VS pin suffice my design.
