Dec 07, 2020
05:30 AM
Dec 07, 2020
05:30 AM
From the datasheet (V 2.2, 2017-01-03) it is relatively clear, that daisy chaining in 8bit-Mode is possible in all topologies from figure 23, because SDI and SSI input is ignored. But how should a command in 16bit mode be daisy-chained?
For 16bit SPI mode 1 (figure 25) daisy-chaining is declared as "supported", but it seem impractical to feed input or wire break data as command to the next chain stage. Any clarification would be highly appreciated.
Thanks and regards
Nazdravi
Thanks and regards
Nazdravi
