Jan 02, 2015
08:30 PM
Jan 02, 2015
08:30 PM
almost every application requires to save and recall some custom settings in EEPROM between power off. Attached is simple component which accomplishes just that. All you need to do is declare some structure to hold application settings and to initialize component. Demo project attached. Tested with PSoc5LP (Creator 3.0).
Several options available: CRC8 check upon recall, variable CRC seed value (can change for different apps), variable EEPROM start address (can use multiple instances of the component to save several buffers), Temperature check for operation in adverse conditions.
odissey1
- application settings
- checksum
- component
- crc
- custom component
- eeprom
- odissey1
- psoc5 eeprom
- restore settings
- save eeprom
- save parameters
- save settings
- settings
- write eeprom
