Dec 29, 2022
12:08 AM
Dec 29, 2022
12:08 AM
I've just wrote my first sample program for XENSIV PAS CO2 Shield2Go for CY8CKIT-044.
Shematic
Pins
Tera Term logs
When the program starts, current command menu is shown.
At this stage, the sensor is in "idle mode"
To see the configuration settings, enter "status" command.
Then each status(es) are shown.
Measurement Rate is set to 5 sec, as the default value of 60 was too large for testing 😉
Entering "run" to the prompt start continous sensing.
I blew my breath to the sensor after 5 measurement,
so the co2 ppm rose there.
After running a while, I entered "stop" command,
which will change the mode to "idle", and the prompt will be shown again.
Entering "help" shows the command again.
moto
Labels
PSoC4 MCU
XENSIV™. CO2
