WiFi Serial Transceiver Module ESP8266
EvPa_264126
Level 7
Level 7
500 replies posted 250 replies posted 100 likes received
I managed to make friends with WiFi Serial Transceiver Module ESP8266
I used for this project  Micro WebServer аё€аёІаёЃ ESP8266 และ Arduino
MicroWebServer.cywrk    project is located   here.
I'll be glad if it is useful for someone.
 Hi Pavloven,
Thanks for attaching the project. I am sure, it will be helpful to many.
Meanwhile, if needed you can update your project to the latest version of PSoC Creator which is PSoC Creator 3.0 SP2. You can download it from:http://www.cypress.com/psoccreator/
Cheers,
PSoC Wonders
I am referring to the project wifi_micro web server given on the above link. I am using that project to interface cybc4242lqibl483 with esp8266. My challenge is my esp8266 is not getting connected to my wifi. The blue led keeps on blinking. When i debug this project the project hangs at wificonnect api. Can you please help me with this issue?
Shailav
Shailav
EvPa_264126
Level 7
Level 7
This project is for a very old firmware (018000902)
You may need to change the project (Data_and_Func.c).
Test  esp8266 by program ESP8266 Config.exe
(https://github.com/AppStackTH/ESP8266-Config)
with AT commands  from Data_and_Func.c
Hello!.
I'm using the ESP8266 with PSoC4 BLE.
Can you please help me out with the coding and the connection part?
It would be a great help.
