Hi all,
Following is a PSoC 5 based load cell measurement system. The project attachment contains Weighing Scale Example and Bridge Sensor Example in the workspace. The Weighing Scale example provides a complete code to measure the weight using a load cell and display the results on an LCD display. The Bridge Sensor example is provided for easily porting the analog front-end example across other sensors. The projects implement Correlated Double Sampling. Moving Average Filter is also implemented to filter the results.
Block Diagram
Schematic Diagram
Hardware required: CY8CKIT-050
Software required: PSoC Creator 4.3
Vasanth
PSoC 345 LP
Nice Sample!
You may want to change the schematic with the one below, which I took from your project with adding a white rectangle background.
moto
Hi Motoo san,
Updated the image as per your suggestion ! Thanks for the feedback.
Vasanth
Hi
How do I calculate this values?
FULL_SCALE_DISPLAY_COUNTS
FULL_SCALE_SENSOR_COUNTS
COUNTS_TO_WEIGHT
Thank you
Dear Vasanth,
Would you be so kind to help me to fully understand your design:
what is the reason / function of 12k resistor between SensorPlus and VSSA ground in your shematic ?
Thanks in advance !
Peter
