UDB I2S programming for separate mode
Kenshow
Level 8
Level 8
Distributor - Marubun (Japan)
50 solutions authored 25 solutions authored 10 solutions authored
Hi all,
I make a CE which is I2S separate mode in PSoC6. The I2S component is introduced the KBA “Import UDB-based I2S Component in a PSoC 6 MCU Project (PSoC Creator) – KBA229971”. This is simple loopback program.
The environment used is as follows:
PSoC Creator 4.4
CY8CKIT-062-BLE
I2S format: 24bit 2word 1bitDelay
Kenshow
Rakshith
Hello Kenshow-san,
Thank you for sharing this example with the community
Rakshith M B
Thanks and Regards,
Rakshith M B
