Overview
The purpose of this code example is to show the users how Status Register polling is done on Infineon serial NOR flash devices.
Requirements
Tool: PSoC® Creator™ 4.4
Programming Language: C (Arm® GCC 5.4.1)
Related Hardware: S25FS512S SPI NOR flash memory, PSoC 6 BLE Pioneer Kit
Software and Driver: Infineon Low Level Driver for SPI Flash
Hardware Setup
This example requires the PSoC 6 MCU’s VDD supply voltage to be set to 1.8V since the FS-S NOR flash device family works at a 1.8V power supply.
Software Setup
This example requires a serial terminal emulator such as PuTTY or Tera Term. Tera Term was used in this example.
Operation
To start any new operation on flash the previous operation must be completed without any errors. After every program and erase operations, status register is polled to check completion status and status of error bits.
In Infineon SPI NOR Flash the status register, in general, have bits assigned to indicate programming error and erase error. In this example, S25FS512S was used, in which the seventh bit of status register 1 (SR1[7]) is Programming error status bit and sixth bit of status register 1
(SR1[6]) is Erase error status bit. If any of the two bits are set, then the user can understand that during the flash operation what error had occurred.
In this example, a polling function is called to perform the repeated operation of polling after every program/erase operation. The polling function consists of an infinite loop that checks if the P_ERR or E_ERR bits are set till the WIP (Write in progress) bit of the status register is 1. Once the WIP bit gets changed to 0, it can be concluded that no error has occurred in the flash operation.
In this code example, we have chosen the S25FS512S SPI NOR flash and interfaced it with PSoC 6 using the SPI protocol.
Steps performed in the example:
- Initialise UART and SPI
- Read Device ID
- Program to the location of 0x040000
- Call the polling function
- Erase the sector starting at memory location 0x040000
- Write to the Status register to implement Block protection. Read the status register to confirm
- Program to the location of 0x040000 (program is unsuccessful)
- Clear the Status Register
- Write to the Status Register to remove the Block protection. Read the status register to confirm
Design and Implementation
Connections:
S25FS512S Flash |
CY8CKIT-062-BLE |
MISO |
P12[1] |
MOSI |
P12[0] |
SCK |
P12[2] |
CS# |
P12[3] |
VCC |
P6_VDD |
VSS |
GND |
PSoC Creator Schematic:
Note: The Slave Select (SS) pin of the SPI block (SPIM_Flash) was disabled. The same pin (P12[3]) was used as a GPIO (Flash_CS) in the project so that the flash CS# line can be controlled manually, as per the requirement of the Infineon sLLD.
Expected Output:
When the example is executed on S25FS512S NOR flash device we get the following output
FlashMemory
ispn:39619:1:0
l1:314:1:0
NORFlash
PSoc6
