Mar 10, 2022
01:04 AM
Mar 10, 2022
01:04 AM
This is a sample code that outputs 8ch PWM using CY8CKIT-149. The 8ch PWM outputs are connected as shown below. The blue wires should be wired.
You can use EZI2C to change the PWM duty from the Bridge Controll Panel of your PC. I attach the pwm_repeat.iic script file.
Click once in the Editor screen and press Ctrl + A to select all. Then click Repeat and the Compare value will change every 500ms.
Thanks and regards,
Labels
CY8CKIT-149
ispn:40045:1:0
l1:314:1:0
03:47 AM
Mar 10, 2022
03:47 AM
Thank you very much for uploading your CE.
Really appreciate your contribution in IFX Developer Community!!
