Hello.
I am working on the SCB UART on the PSoC 62 MCU. I have using Modus Toolbox for code generation. I have configured SCB 6 UART with DMA using the PDL library. The data is being received and transmitted successfully But when change the UART mode from Standard UART to IrDA and test it with IrDA module the data is being transmitted and can be observed in on the serial monitor using an IrDA data link.
What is causing this problem. Do I need to implement some kind of flow control to make it work?
Everything is set properly as I change the UART mode back to standard It starts working correctly.
Any kind of help will be highly Appreciated.
Can any Person describe the steps to configured UART in IrDA mode?
IrDA UART reception not working.
Hi @AfaqAzeem ,
I see that you have created a duplicate thread relevant to the issue: https://community.cypress.com/t5/PSoC-6-MCU/SCB-IrDA-UART-reception-is-not-working/td-p/289534 . I am closing the discussion here so as to avoid the confusion. We can continue the discussion there. Thank you very much for understanding.
Aashita
