haor_4285216
First like given
Hello.
I am new to PSOC
I am trying to measure the duty cycle of PWM signal, and I do get the high count right, but I do not get the low count and the period.
I attached the Oscilloscope screen, from the PWM module output on pin m_2.
Attached the main C file.
Attached the UART output.
Hanan.
Hi Hanan,
I attached the new project which can measure the duty cycle of PWM signal.
You need to check the PWM capture and reload trigger signal. And the getcapture API parameters.
capture2 = Cy_TCPWM_Counter_GetCapture(Counter_2_HW, Counter_2_CNT_NUM);
capture = Cy_TCPWM_Counter_GetCapture(Counter_1_HW, Counter_1_CNT_NUM);
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
Could you attached your test project?
The project is attached.
Hanan.
Hi Hanan,
