Need Example Code for Simultanously 2 filter output with one output filter changable to LPF/BPF/HPF in PSOC 5LP
PSoC 5LP
Please find one example attached where filter cut-off is changed dynamically. By default, Filter is configured to LPF, 50KHz cut-off. If you press the switch , the filter will change to LPF, 10KHz cut-off. If you press the switch again, it will toggle the Filter back to LPF, 50KHz cut-off.
Vasanth
Vasanth
Could you please right click on the project and select update component option?
Vasanth
Thanks For Reply Now Components Updates Ok Our Filter Coeff as Follows
Final coefficients for Biquad filter :
Coefficients are in the order A0, A1, A2, B1 and B2
1
-2
1
-1.9898898601532
0.989932298660278
1
-2
1
-1.98847961425781
0.988522052764893
1
-2
1
-1.98750925064087
0.987551689147949
1
-2
1
-1.98701500892639
0.987057447433472
1
-2
1
-1.9916877746582
0.991730213165283
1
-2
1
-1.99380564689636
0.993848562240601
1
-2
1
-1.99616479873657
0.996207475662231
1
-2
1
-1.99867510795593
0.998717784881592
0.000113010406494141
0.000226020812988281
-1.97501468658447
0.975395441055298
8.24928283691406E-05
0.000164985656738281
-1.98127722740173
0.981659173965454
0.000104904174804688
0.000209808349609375
-1.96971988677979
0.970099687576294
0.000108480453491211
0.00021672248840332
-1.96557974815369
0.965958833694458
7.77244567871094E-05
0.000155210494995117
-1.9882824420929
0.988665819168091
0.000114679336547852
0.000229120254516602
-1.96273803710938
0.963116407394409
0.000115871429443359
0.00023198127746582
-1.96129250526428
0.961670637130737
0.000298500061035156
0.000597000122070313
-1.99577355384827
0.996158599853516
ie Stage1 and Stage2 Biquad BPF Butterworth filter
How can i load this type of Co-eff on the Pgm ?
