Translation_Bot
100 likes received
According to the KBA: ModusToolbox ™ Manifests Repositories, you can infer from it that the official ModusToolbox ™ Manifests Repositories are hosted on github.com.
According to this KBA: ModusToolbox ™ Manifests Repositories, you can learn that the official ModusToolbox ™manifest repository is hosted on github.com.
Sometimes the service of github.com is not available in some Countries/Regions. Hence I mirrored them to gitee.com. another website providing Git repo services.
However, the github.com service is sometimes not available in some countries. So I mirrored a copy of these manifest repositories and put them on gitee.com. gitee.com is a website similar to github.com which also provides Git repository services.
If you can't access the official manifests, you can turn to the mirror repos for help.
If you don't have access to the official list, you can rely on these mirror repositories.
Usage is kept the same with the KBA above. All you need is to replace the official links with the mirror links below and follow all other steps. You may need to combine these two articles to get what you need.
The method of use is the same as the KBA above. All you need to do is replace the official link address with the mirror link address below, and the rest of the steps remain exactly the same. You may need to combine these two articles to get the information you need.
Infineon's standard manifests (mirror)
Infineon's standard manifests are the basic manifests for ModusToolbox ™. They denote the core boards, example projects, libraries, and library dependencies of ModusToolbox ™.
Manifest repo root Super-manifest links of the repo
https://gitee.com/dreamscaperia/mtb-super-manifest
https://gitee.com/dreamscaperia/mtb-super-manifest/raw/master/mtb-super-manifest-fv2.xml
https://gitee.com/dreamscaperia/mtb-super-manifest/raw/master/mtb-super-manifest.xml
Infineon's supplemental manifests (mirror)
Infineon's supplemental manifests are the supplemental manifests for ModusToolbox ™. They denote the additional boards, example projects, libraries, and library dependencies of ModusToolbox ™ which are not covered in the standard edition .
Manifest repo roots Super-manifest links of the repo
https://gitee.com/dreamscaperia/mtb-psoc62s4-manifest
https://gitee.com/dreamscaperia/mtb-psoc62s4-manifest/raw/master/mtb-super-manifest.xml
https://gitee.com/dreamscaperia/mtb-psoc4000t-manifest
https://gitee.com/dreamscaperia/mtb-psoc4000t-manifest/raw/master/mtb-super-manifest-fv2.xml
https://gitee.com/dreamscaperia/mtb-psoc4000t-manifest/raw/master/mtb-super-manifest-fv2-beta2.xml
https://gitee.com/dreamscaperia/mtb-t2g-super-manifest
https://gitee.com/dreamscaperia/mtb-t2g-super-manifest/raw/master/mtb-super-manifest-fv2.xml
https://gitee.com/dreamscaperia/mtb-xmc7000-manifest
https://gitee.com/dreamscaperia/mtb-xmc7000-manifest/raw/master/mtb-super-manifest-fv2.xml
https://gitee.com/dreamscaperia/partner-super-manifest
https://gitee.com/dreamscaperia/partner-super-manifest/raw/master/partner-super-manifest-fv2.xml
https://gitee.com/dreamscaperia/cce-super-manifest
https://gitee.com/dreamscaperia/cce-super-manifest/raw/master/cce-super-manifest-fv2.xml
https://gitee.com/dreamscaperia/mtb-connected-sensor-kit-manifest
https://gitee.com/dreamscaperia/mtb-connected-sensor-kit-manifest/raw/master/mtb-connected-sensor-ki...
https://gitee.com/dreamscaperia/mtb-cyw20829-manifest
https://gitee.com/dreamscaperia/mtb-cyw20829-manifest/raw/master/mtb-super-manifest-fv2.xml
https://gitee.com/dreamscaperia/mtb-psoc4-manifest
https://gitee.com/dreamscaperia/mtb-psoc4-manifest/raw/master/mtb-psoc4-super-manifest.xml
https://gitee.com/dreamscaperia/mtb-psoc4smax-manifest
https://gitee.com/dreamscaperia/mtb-psoc4smax-manifest/raw/master/mtb-super-manifest-fv2.xml
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E4%BE%8B%E7%A8%8B/Mirror-of-the-ModusToolbox-Manifests-Repositories/td-p/498281
