I am uploading annotation component for the CY8CKIT-042 PSoC4 Pioneer Kit.
The component helps visualizing ports and pins and creating connection diagrams for CY8CKIT-042 PSoC4 Pioneer Kit. It shows pins with direct connection to the ADC_SAR bypass capacitor, OpAmps, USB-I2C bridge, USB-UART bridge, RGB LEDs, Capsense pad, Switch and PMOD connector.
The KIT-042 annotation component can be used in conjunction with Cypress stock annotation components (capacitors, resistors, etc.) as well as small-sized annotation components from the complimentary PSoC Annotation Library:
Attached archive contains KIT-042 component library. Upon installation it will show up in the folder:
/Community/Off-Chip/Annotation Library/Kits/
The component provided as-is, no liabilities. It is free to use, modify and distribute.
regards,
odissey1
Figure 1. Component default appearance
Figure 2. Typical component use in conjunction with complimentary PSoC Annotation Library (Diffeferntial pre-amp example).
PSoC 345 LP
- annotation
- annotation component
- annotation library
- community component
- cy8ckit-042
- cypress
- kit-042
- library
- pioneer board
- pioneer kit
- psoc4
- psoc4200
