07:55 PM
Mar 18, 2015
07:55 PM
hi all I have a GLCD 128 * 64 programmable parallel form or series but have not been able to apply the right way the library GLCD q psoc 5 gives us algien I could esplicar in a clear way works well this library thanks. . attached data sheet of the GLCD .... happy evening and greetings to all.
04:08 AM
Mar 19, 2015
04:08 AM
The Creator library for graphical display is designed more for displays without internal controller. I think you need to roll your own code.
I found some sample code here: http://www.toughdev.com/2013/11/experimenting-with-st7920-128x64.html . You can use either parallel or SPI connection - the parallel one might be easier for a start (and it can do even 4-bit-mode).
09:05 AM
Mar 19, 2015
09:05 AM
Thanks very much for your help agradesco
It is the first time I meet some info
or something with this code on such GLCD
this invalidation is a big help
to begin with, thank you very much .
