Hello....
Starting with Cypress controller, what development kit or code examples helps me to develop small test application to verify the proper working of UART, SPI, I2C, GPIO, Clocks etc. peripherals.??
I have IAR 8.4 Workbench IDE for programming and debugging code, so looking for example codes in IAR IDE support.
Development Kit
SDK
- development kit
- sdk
As Hari-san has mentioned, it seems that we can export PSoC Creator Project to IAR and other IDEs.
So if you "can" put up with installing and using PSoC Creator, which is free,
I have written and posted the following sample projects to show how to use basic peripherals.
PSoC 6
CY8CKIT-062-BLE
CY8CKIT-062-WiFi-BT
https://community.cypress.com/t5/Code-Examples/MCU-Tester-a-Swiss-Army-Knife-for-PSoC-CY8CKIT-062-BL...
PSoC 5LP
CY8CKIT-059
https://community.cypress.com/t5/Code-Examples/MCU-Tester-a-Swiss-Army-Knife-for-PSoC-CY8CKIT-059-ve...
PSoC 4
CY8CKIT-044
https://community.cypress.com/t5/Code-Examples/MCU-Tester-a-Swiss-Army-Knife-for-PSoC-CY8CKIT-044-ve...
moto
Note: Sorry I have not tried to use these with IAR tools.
Hi @Suma
You can take a look at our PSoC 4 and PSoC 6 devices. PSoC 4 are low power application devices with a cortex M0+ processor and PSoC 6 provides connectivity options as well with a dual core (CM4 + CM0+) architecture.
PSoC 4 MCUs - https://www.cypress.com/products/32-bit-arm-cortex-m0-psoc-4
PSoC 6 MCUs - https://www.cypress.com/products/psoc-6-microcontrollers-32-bit-arm-cortex-m4m0
Hari
Hello Hari,
Thanks for the response, as I have mentioned looking for development kit code examples in IAR IDE support. I can't run code on PSoC.
Hi @Suma
You can port the code examples and projects to IAR as well. Please have a look at this thread - https://community.cypress.com/t5/PSoC-Creator-Designer-Software/IAR-in-PSOC-Creator/m-p/143301 and the PSoC Creator User guide - https://www.cypress.com/file/137441/download Section "Exporting a Design to 3rd Party IDEs"
Hari
PSoC 6
CY8CKIT-062-BLE
CY8CKIT-062-WiFi-BT
PSoC 5LP
CY8CKIT-059
PSoC 4
CY8CKIT-044
moto
