Hi.
This sample uses CY8CKIT-149.
This sample displays the Cp values of each buttons to the serial terminal at start up.
After that button press(es) will be reflected to the corresponding LEDs.
I hope this sample helps in evaluating CapSense.
schematics
Pin list
main.c
* Included Headers
#include "CapSense.h"
#include <project.h>
#include "stdio.h"
* MACRO Definitions
#define LED_ON (0u) /* Pin state to turn ON an active-LOW LED */
#define LED_OFF (1u) /* Pin state to turn OFF an active-LOW LED */
/* Finite state machine for device operating states
SENSOR_SCAN - Sensors are scanned in this state
WAIT_FOR_SCAN_COMPLETE - CPU is put to sleep in this state
PROCESS_DATA - Sensor data is processed, LEDs are controlled,
and I2C buffer is updated in this state */
typedef enum
SENSOR_SCAN = 0x01u,
WAIT_FOR_SCAN_COMPLETE = 0x02u,
PROCESS_DATA = 0x03u,
} DEVICE_STATE;
* Function Prototypes
void TestSensorCapacitance(void) ; /* same with CapSense_RunSelfTest(CapSense_TST_SNS_CAP) ; */
void cls() ;
void print(char *str) ;
#define STR_LEN 64
char str[STR_LEN+1] ;
int main()
/* Variable to hold the current device state
* State machine starts with Sensor_Scan state after power-up
DEVICE_STATE currentState = SENSOR_SCAN;
/* Enable global interrupts. */
CyGlobalIntEnable;
//sizeof(CapSense_dsRam),
//(uint8_t *)&(CapSense_dsRam));
CapSense_Start(); /* Initialize Component */
/*CapSense Cp value check */
CapSense_RunSelfTest(CapSense_TST_RUN_SELF_TEST_MASK) ;
UART_Start() ;
print("CapSense cp\n ") ;
snprintf(str, STR_LEN, "BTN0(%d) BTN1(%d) BTN2(%d) \n\r",
CapSense_BTN0_SNS_CP0_VALUE , CapSense_BTN1_SNS_CP0_VALUE, CapSense_BTN2_SNS_CP0_VALUE ) ;
print(str) ;
for(;;)
/* Switch between SENSOR_SCAN->WAIT_FOR_SCAN_COMPLETE->PROCESS_DATA states */
switch(currentState)
case SENSOR_SCAN:
/* Initiate new scan only if the CapSense block is idle */
if(CapSense_NOT_BUSY == CapSense_IsBusy())
#if ENABLE_TUNER
/* Update CapSense parameters set via CapSense tuner before the
beginning of CapSense scan
CapSense_RunTuner();
#endif
/* Scan widget configured by CSDSetupWidget API */
CapSense_ScanAllWidgets();
/* Set next state to WAIT_FOR_SCAN_COMPLETE */
currentState = WAIT_FOR_SCAN_COMPLETE;
break;
case WAIT_FOR_SCAN_COMPLETE:
/* Put the device to CPU Sleep until CapSense scanning is complete*/
if(CapSense_NOT_BUSY != CapSense_IsBusy())
CySysPmSleep();
/* If CapSense scanning is complete, process the CapSense data */
else
currentState = PROCESS_DATA;
break;
case PROCESS_DATA:
/* Process data on all the enabled widgets */
CapSense_ProcessAllWidgets();
/* Controls LEDs Status based on the result of Widget processing. */
LED_13_Write(CapSense_IsWidgetActive(CapSense_BTN0_WDGT_ID) ? LED_ON : LED_OFF );
LED_12_Write(CapSense_IsWidgetActive(CapSense_BTN1_WDGT_ID) ? LED_ON : LED_OFF );
LED_11_Write(CapSense_IsWidgetActive(CapSense_BTN2_WDGT_ID) ? LED_ON : LED_OFF );
/* Set the device state to SENSOR_SCAN */
break;
* Unknown power mode state. Unexpected situation.
default:
break;
void cls(void)
print("\033c") ; /* reset */
CyDelay(20) ;
print("\033[2J") ; /* clear screen */
CyDelay(20) ;
UART_UartPutString(str) ;
/* [] END OF FILE */
Asanuma
PSoC 345 LP
Hello Asanuma-san,
Thank you for sharing your example project with the community.
I see that you are using CapSense V5.0 in this project, the latest CapSense version is CapSense V7.0 and we recommend using this for new applications.
Hari
